Fuel indicator problem in Maruti 800
delhi
Hi mine is 1996 maruti 800 but it has wird fuel indicator problem. I mean it doesnt show right amount of fuel and also the fuled needle keeps on movings as i drive up and down [confused]
Oops. Perhaps everybody missed this thread. I believe there could be some problem with the sending unit. Did you show it to a mechanic?
zengetz
NA
This is something you will have to get checked from a service center. It could be a faulty guage, the float device that sends the signal for the fuel level in the tank could be messed up.
delhi
wELL IN MY 97 M800 THE FUEL GAUGE USED TO SHOW THE CORRECT RATING NUT WHEN THE GAUGE USED TO REACH A LITTLE BIT ON THE LEFT SIDE OF HALF MARK IT USED TO STRAIGHT GO BELOW EMPTY SO I GOT THE THE DEVICE INSTALLED ON THE PETROL TANK CHANGED FOR RS. 400+LABOUR N THE GAUGE WAS BACK TO NORMAL.
