Hi Friends..
Here I am presenting a Diy which was done by me and boostergauge which shows how to install a electric vacuum pump and a oil catch can.
A long time project (almost 3 months)
Vacuum pump used - Volvo S40 (bought from EBAY)
Other things like hose pipes, valves also the vacuum switch were sourced from EBAY (except hose pipes)
The main reason for the installation of Vacuum pump is, as 800 does not have capacity to generate the sufficient vacuum need for brake booster so we are now using this pump instead of drawing vacuum from the intake manifold. Here we are using Zen booster.
Vacuum pump is widely used in other countries, especially in electric cars.
So finally the result is good, we are still testing.
The only thing which is bothering is, the pump gets heated up soon.
Next comes the oil catch can, we is used to collect the oil and water vapor which is passed from engine head to throttle body which makes the throttle body oily and sticky which restricts the air flow.
We have used a aluminum water bottle and 2T brass junction also used steel scrubber which is used as a filter (inside the bottle)
And we have connected it between the pcv valve.
Finally we have also swapped a battery from Accent which is 75 amps. Maruti 800 batter by default is 35 amps, the model no is Din55 (accent battery) Does its job pretty well. Just need to change the battery terminal clamps as they are bit big than the stock ones.
Here are some pic's I will write more about it later. Hope you guys liked it.
