DIY Switch Controlled LED Lights Setup
chennai
Hi TAI friends,
I think many of you would like beautiful lights placed in many parts of your bikes.this DIY is dedicated for you guys.
you will need:
1.any type of 12v DC lights(I prefer LED as they consume very less power).
2.Wires(I have used speaker wires in this setup as LEDs draw less power).
3.A switch(You can get one from an automobile stop).
4.a Blade
5.Insulation tape
Procedure:
1.locate the ignition socket (the socket which is in the bottom of the key set)
2.most of the bikes need the headlight assembly/the mask/fairing to be removed to locate the socket.
3.slowly remove the insulation on the black wire of the socket to hook up the live(positive) wire for the LED setup.
4.connect the wire and tape it carefully.
5.now take another wire and connect it to any dark green wire(negative).
6.after installing the LED lights to the desire parts or position connect them with the positive and negative wires drawn from the socket.I prefer to lay the wires under the petrol tank to make the wires hidden.
7.A switch needs to be placed in-between the positive wire to control the supply of current.(Refer image for perfect mapping).
8.Voila.You have perfectly completed a LED light setup.[clap]
Note:
*The red and black wire in the first image are the wires for the setup.
*The above setup draws power directly from battery.so try not to put too much load to it.
*The current passes through only after turning the bike ON(Engine need not be started).
Please leave your comments on the DIY and feel free to ask any questions.
INDIA
Re: DIY switch controled LED lights set up(with images)
Hi harikishen95,Nice DIY.Please post pics after installation.
Hi harikishen95 ,
Thank you for very informative and much needed post for me.[clap] It look like you have Hero Splendor. I have Honda CB Unicorn and I want install same lights. Is green and black wires under head same for Unicorn?
