DIY: My Rockstar Swift VDi Interior Map Lamp Bulb Swap
Coimbatore (CBE)
Friends i Did DIY in my rockstar swift's reading lamp bulb from normal OEM Bulb to LED Fesston. the results were fantastic.
Step by step:
1. remove the lamps glass (there will be 4 clips in black in the corners)
2.Remove the housing plastic of the reading lamp
3. Remove the OEM Lamp bulb
4. Fit the fesston bulb in the place of the stock bulbs
5. Refit the housing plastic of the lamp
6. Fit the Glass panel of the lamp
(NOTE: CHECK THE BULB WHETHER THE BULB IS WORKING OR NOT BEFORE REFITTING THE HOUSING AND GLASS)
And its done.[:)]
Bought it in Aliexpress:100/- (free shipping)
Recieved it within:15 days after ordering
Attaching some pics of it
Benefits:
1. Brighter than the stock ones
2. Looks cool and pleasing
3. Consumes less power than the OEM's
4. Covers all the places of the car.[:D][clap]
Before starting the DIY (notice the black spots on the corners)
OEM Bulb lighten up
clear pic of it
the feston that i received with the packing
the bulb inside the packing (sorry for the blur)
comparison between the stock ones and the LED Feston
LED Feston fitted inside the housing
LED Feston lighten up notice the difference
Fitted the housing back to the Roof and also the glass panel has been fitted back
and the result satisfying 100%
And thanks to Anurag his DIY only helped me a lot to fit the led Feston thanks a lot anuraag once again.
Coimbatore (CBE)
Re: DIY:My Rockstars Swift VDi Interior Map Lamp Bulb Swap
thank you bhvm and its again all because of anuraag. and thanks bought in aliexpress. and still there is some other DIY'S are remaining for that the Equipment has to come.
Coimbatore (CBE)
some night time pics of the interior after fitting the led feston. and now recently fitted number plate white lighting same sort of DIY attaching some pics of it too.[:)]
the set with packing
the stock bulbs liten up
OEM Bulbs on left and the OSRAM LED's on the right comparo
OEM Bulbs and OSRAM LED's lighting the number plate brightness comparison
after fitting the OSRAM LED's on both sides Work over, 100% satisfied
