DIY Kick Open Tail-Gate On Maruti 800 Using Arduino
KOLLAM
After long time i logged in to TAI. This is my new DIY
you can find more details in the video link.
Circuit Diagram
Arduino Code.
Code:
const int trigPin = 11;
const int echoPin = 10;
const int relayPin = 13;
long duration;
int distance;
long distancemm;
void setup() {
// put your setup code here, to run once:
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
pinMode(relayPin, OUTPUT);
void loop() {
digitalWrite(trigPin, LOW);
delayMicroseconds(0);
digitalWrite(trigPin, HIGH);
duration = pulseIn(echoPin, HIGH);
distance= duration*0.034/2;
distancemm = distance*10+30;
//Control
if (distancemm <= 230)
for (int i=0; i <= 180; i++){
digitalWrite(relayPin, HIGH);
delay(10);
else if (distancemm >= 231)
digitalWrite(relayPin, LOW);
else
delay(10);
Navi mumbai
Circuit Diagram
Arduino Code.
Code:
long duration;
int distance;
long distancemm;
void setup() {
void loop() {
//Control
delay(10);
else
delay(10);
This is a very informative video, this clearly shows that such modern techniques are so doable, yet manufacturers skip these things. I will surely try this on my Alto K10 once its warranty is over.
Just wanted to know if you have made any changes to the stock struts and opening mechanism of the boot as it lifts off completely after getting unlocked?
Also what happens in case there is mud and other things thrown on the sensor during rainy day drives, will it respond to it also and open up?
KOLLAM
yeah i added an additional dicky shock for auto-opening. there is no way for mud splash over the unit,it wont respond to mud. you ccan try with waterproof IP67 ultrasonic sensor
