DIY FIBERGLASS Sub Woofer Enclosure, Speaker Box for my Scorpio
chennai
hi every one,
i am starting this threat to show how i did my sub encloser[:)] and speaker box in my scorpio. i also changed my door pads colour
mateials and cost:
1. sub woofer encloser box - i allready had one
2. plywood - SQ feet cost me Rs.33 i got 4X6 but i didn't use it fully
3. wood stapler - Rs.325
4. old t-shirt
5. fiber glass mat - Rs.200 per kg i got 2Kgs
6. fiber glass resin - Rs.120 rs per kg got 4Kgs
7. fiberglass activater - 100ml Rs 150
8. fiberglass hardner - 100ml Rs 200
9. rexine mat for door padding Rs 250 for 2 sq meters
10. fevical SR for sticking mat to door pads Rs 100
first Picture before of my old box and door pads
chennai
I started by cutting the top of the woofer box and made a pentagon out of the same wood and positioned it with a support. Then took an old banian and wrapped it with that. On the other hand I started my speaker box too. I had to normal folds which were used to fix to speaker in the doors. I joined both that in by plywood on its back and check that my speakers will fit, then I made a base for that, decided how I want that to look like and positioned it on the base. Once again the same wrapped it with a shirt. but at that time i didn't have wood stapler [frustration]used small nails.
vijay
Moderator
Ahmedabad
intresting, would also like to see did you did any sound dampening on your doors as well, awaiting to see the complete project.
chennai
@truecitylover: you are right. You can just pull the cloth in the way you want and press the trigger pin comes out like a bullet penetrates the wood and hold the stuff in place. If possible in the next post I will post my stapler's pic in the next threat.
chennai
Here is some more picture of my WORK [thumbsup] . i got a new wrap for the door pad and now it look better. i will post that pic soon.s
MAN you are just revealing our jobs!
method is 100% perfect
But the sub box and collor are wood. why u need a fibre glass only on top.
imo entire thing must be made in fibre glass to reduce space and take shape of the car!
chennai
Actually I didn’t have any experience that time that is my first DIY. So I thought of trying some thing that it and now I thinking of going it the way you said[cheers]
Excellent DIY job Thomas.
DIY stuff needs a lot of patience for proper execution, which you seem to have in abundance.
yeah you need patience and tools to smoothen the outcome of fg .
then putty work to mould them
Your door pad looks too rough , good for a diy.
WORKING with FIBRE GLASS IS HIGHLY CARCINOGENIC. esp while grinding them
Thread Starter #15
chennai
@ilango[speed thirst]: i have changed my door pad now once again and i have wrapped my speaker box with the same stuff i used for the pad.
@auto luver: i will come up with the pic soon by the next post possible.
@akash: thanks dude. i will soon post my othe DIY i did.
really thanks for all you peoples reply. THANK YOU.
