Parts required:
1) LED Light
Either a LED strip or the blocks should do, color choice is personal. I'm using block type (3 LEDs) white LEDs, 2 Nos for either side and couple of T10 LEDs for cabin lamp
2) Wire
I had wires left from my previous project (forgot about the spec / gauge) Approx 4m will be required
3) 2 way switch
This is optional. I'm using the 2 way switch to operate the foot well lamp in dual mode.
Mode 1: Operates with the cabin lamp (Door Switch / Cabin lamp switch)
Mode 2: Dedicated power (irrespective of doors open / cabin lamp switched on or off)
4) Snap fit connector
To have detachable / removable connection from the cabin lamp to the rest of the circuit. This again is optional. I used the one from one of my left out wiring harness.
5) Fuse & Holder
I ordered through Aliexpress and awaiting delivery. Will be installed after the snap fit connector once it is delivered.
6) Heat Shrink sleeves
Optional, you may use insulation tapes as well. But heat shrink tubes are safe bet with professional touch.
Tools Required:
- Wire Stripper
- Screw Driver (to remove the cabin lamp)
- Scissor (To cut the heat shrink tubes)
- Soldering Gun
- Heat Gun / Lighter (to heat the heat shrink tubes)
