Correct order of changing tyres
ynr
hey guys as i had to change my 2 tyres which bursted due to an accident . i had replaced one with the extra tyre and bought a new one . both tyres bursted were driver side . the new tyre was put in front and stepney at rear .
my car has run 7000 kms so my right side tyres are new and left are old will this create any problem??
is there any order to put the tyres??
thanks
Put the tyres which are worn out more at the rear and the new ones at the front. Since your car is a FWD the front tyres wear out sooner than the rear ones.
In your present case i think you can feel some difference in driving slightly , the car will not be stable while cornering.
Generally, it is recommended to replace all four tires together, but there is no thumb rule, especially in case like yours, since the car has covered only 7,000 Kilometres, I assume that other two would be in a fair enough condition, and all tires retain the same size. However, you can do what cooldhaya has stated in above post.
