Constructing Off Road Baja Vehicle Using Maruti 800
MUMBAI
hi, guys i m sidd NEED SOME HELP from all you guys...
i want images of MARUTI 800 hub of wheel on whish we bolt A-arm ..the whole assembly
i wanted to see what are the mounting points for A-arm ,tie rod & all, also it must suitable for R12 rim coz i have to install ATV tires of R12 on it [confused]
Re: Maruti 800: Conversion to Off Road vehicle
Sidd can you please give us a bit more context on what and why you plan to do this conversion ? There are quite a few M800 gurus on the forum , but appreciate if ou can give more insight on what/why you plan to do this conversion ?
MUMBAI
Re: Maruti 800: Conversion To Off Road Vehicle
yes i would like to explain more about this. .at 1st thnx for replying me. i m not converting MARUTI 800 to off road vehicle. i m constructing OFF-ROAD baja using parts of MARUTI800 hub ,gearbox of MAHINDRA-ALFA. now completed with design of ROLLCAGE only. i w'll lucky if you give suggestion on how to calculate suspension angles & mounting,castor camber like things.
