Chevrolet Aveo U-VA LS Engine Problem
kangra, H.P
Hello sir, I own Chevy Aveo U-VA 2010 model done 135000 Kms. The problem is that the engine turns off with a/c on when shifting gears and also the pickup has dropped by almost 40% and the car shakes up and down when standing still on neutral. Do you have any solution to this problem? Also the car takes long self start and emits strange smell after starting.
kangra, H.P
Did you consult service center what is their suggestion. When did you change clutch assembly.
sir they are unable to figure out the problem and nothing has been changed from the day I bought the car.....only clutch plates have been changed so far...also the gear shifting has become harder
Do they changed only clutch plate or full assembly like Cover plate and releaser bearing. If those are not changed those are the culprits. But still figuring out why car shaking up in neutral, Check engine bedding. Try to do fuel pressure and compression check of all cylinders.
