Car: Dzire 2009 Lxi
Tyre Size: 165/80 R14
Driving style: 75% bad roads
OK MRF is fine but if you can afford 4k on each tyres then go for
Bridgestone TURANZA AR20. You get decent comfort, grip and it should run fine over bad roads.
I have been advised not to go for higher size because Lxi has steel rims,not alloys.
Whether you have steel or alloy wheels, upsize doesn't matter much with it but all the 4 tyres should be same size otherwise internal parts will be worn or damaged.
Well since I am replacing only 1 tire, 1 tire as 185/70 and other 3 as 165/80 will affect my car, no?
Also why 70 and not 80?
Oh I see, So like I said above don't mix different size tyres. Get the same size as others and also same brand/model if possible.
As you already know, the first block of three digits is the width of the tyre measured in mm and the second block of two digits (i.e 80, 70) is the height of the tyre sidewall measured as a percentage (Aaspect ratio) of the width. In your case: 80% of 165 is 132mm and upsize: 70% of 185 is 129.5.
The sidewall height of the upsized tyre should be less then +/- 3% to OEM tyre size, otherwise the tyre will touch the wheel arch/well.
Now you can buy the OEM size and use it till other tyres wear out, then upsize all the 4 tyres and use one of old tyre which is in good condition as spare. Using different size tyre for limited distance is fine but it shouldn't be used as regular.
In 185/70 r14 size, there are lot of different tyre brands and models to choose. Continental, Bridgestone, Michelin, Yokohama & etc.
You drive on bad roads? so what? Where are good roads in India?
