Brakes Problem in Maruti 800
delhi
Brakes of my maruti 800 ,1996 model are were poor now and take time for stopping the car. Also i fill break oil every month but at end of month it is finished and i get warning light .
what to do [surprise]
Varun560061
Re: brake problem in maruti 800
I guess there is some leakage in your braking system, mostly the leakage will be in the cylinders in rear drum..check them out it ll solve the problem.
And for more power you can istall the booster brakes(vaccume brakes).
If you need details I can share with you..
Rajahmundry
Re: Brakes Problem in Maurti 800
do you find any oil, on the ground when parked the car over night????
vaccum brakes for m800??? i dont think it would be a good idea for 800
Fixing the vacuum brake makes it like a modern day car. also a easy job in 800.
SELECT a empty road.
drive around 30+ like in 40 or 50kmph,
leave the hands from steering and brake.
does it pull?
if yes , sure sign of leaking in brake cylinder!
hmmm else it just takes 20 min to open up rear brake drum. mech must help!
Varun560061
Hi I have done it on my car, it works fine, above expectation..
Rajahmundry
from near which tire oil is leaking, get that inspected. in most cases brake cyclinder go kaput
varun560061
how much does it costs. & details of vaccum brakes
Varun560061
varun560061
Hi, It costs me 5k for the whole assembly and fitting, these brakes are already fitted in all new cars. Even Omni and nano(cx\lx) has it now.
I will post the pictures of the booster later..[:)]
shillong,meghalaya
Brake Problem
I have a maruti car800,model 2002,MPFI engine. The problem is that the brake is not working,every thing has been checked and is ok but is not not working,the brakes need to be pumped for 7-8 times to stop the car. So how does it happen like that?
M.P.
Re: brake problem
Seems like you need to get the master and slave cylinders serviced/replaced. Ask your mechanic to check them out.
Re: brake problem
Also if possible try to get the booster installed (can make a huge difference). total cost of Brake booster install, along with a few parts change in drum will come to about 5000/- (max, including labour)
NCR
Re: brake problem
You have to check the master cylinder if its o then there is chances that its due to air bubble in brake line or any of break cylinder have minor leakage that result in making air bubble in line.
Varun560061
Yes it would work for 2-3 times (till the vacuum exists in the booster) then the pedal would get hard and the brake wont work as it should.
