Booked I20. Suggestion for ICE upgrades ?
lucknow
Tired of waiting for a car after booking Jazz in September. And the wait seemed endless . Cancelled the booking after 3 months and booked I20 Asta and expecting it Jan 1st week.
I want to upgrade ICE. Plz any suggestions . Is it required or not ?
lucknow
Not thouht about the budget yet. But dont want to change te HU.May be addition of amplifier and subwoofer and change of speakers. Also other small changes if required. Just want that the car shud not be disturbed much.
I want to improve the sound. Dont want it to be outstanding.
Suggest me considering me as an amateur.
Dubai / Mumbai
Front component speakers
rear component speakers or co-axials
4 ch amp to power speakers
subwoofer in boot
2 ch amp or mono amp to power sub
hi to low converter for stock head unit
6 guage wiring + power cables
and you are good to go. you can select from a range of brands, depending on your budget.
Noida
Can you please check to see if the stock headunit has RCAs. If not, prefer the amp with line level inputs.
For fronts - 6.5" component drivers from JBL, Hertz, Morels, DLS
For rears (if required) - 6x9 drivers matched to fronts (listen to pick)
4 ch amp - JBL 1004, kenwood 846.
Wiring - prefer connection audison.
Amp kit - pick a trusted one.
Damping - if required.
freakdude.
lucknow
subwoofer in boot
Thanks a lot for the info. This information is good enough. May be i can select the brands based on my budget.
But approx much much do i hv to spend ?
lucknow
freakdude.
Thanks bro. Still which brands wud you prefer ?
Noida
Buddy, ICE has endless possibilities. Just an idea, front compos can vary from 4K to 200K. So it would be better if you could share your max upper limit for the ICE, so that we can suggest brands. [thumbsup]
freakdude.
Dubai / Mumbai
For a decent system, you need to spend some 20k, for a good system, you spend some 35k, for a mind blowing system, there is no limit !
