Ahmedabad
Never used the Bosch. Many were complaining of overheating issues with it. Been using G-Power since almost the same year I bought the bike. Bike cranks easily at any cold temp comparing stock. Apart from that nothing really noticeable. It's maintenance free. Fit it, forget it. No cleaning or gap adjustment needed.
Yup, thanks for the reply, I upgraded the spark plug from stock to NGK GPower CPR8EAGP. After upgrading, the initial Rpm have reducec from 2500 to almost 2000 but I had observed a very good change in the throttle response which has become more crisp now and the acceleration is more linear.
Also, I am going to change my front tyre and earlier I had already changed the rear to Michelin Pilot Street Radial 140/70-17 and they are a joy to ride. I am confused if 110/70-17 would better fit the front alloys. Does this combination affect the Rake and stance of the bike? I think it will exert more load on the front shockers.
Thread Starter #347
Not much difference in ride height, more planted and bit heavy.
Thread Starter #349
Fork Overhaul
One of the forks started leaking and decided to overhaul both sides completely.
Fork Oil Seal - 4EB-23145-01 - ₹ 250.00 x 2
Compared with old snaps and found GT had the same ones, exact same. RE packing ₹ 315.00 and hard to get.
Changed spring also this time.
Front Fork Spring - 21C-F3141-00 - ₹ 80.00 x 2
Endurance Fork Oil - 350 ml - ₹ 100.00 x 3.
350 x 3. Needs 460 x 2.
Couldn't get Motul as there seems shortage of it and all were stocking KBX and Endurance.
Changed dust seal in one of the forks. Lost the snaps somewhere.
Fork Dust Seal - 4EB231440000 - ₹ 205.00
Snap Ring - 21CF31561000 - ₹ 7.00
Removed forks and got it changed at our regular Honda FNG, Vinayak Honda. Charged ₹ 450.00.
Total damage - ₹ 1672.00
Removing these 2 bolts after removing mudguard and brakes removes the fork without touching headlight and all.
Assembling back.
Done.
Carb Cleaning update:
Throttle was getting stuck and found that butterfly was getting stuck. Disassembled and lubed both side pivots of butterfly and working now perfectly. Now throttle is smooth and carb response is better. Flying past 6k rpm is breeze.
Thread Starter #350
Got new pair of brake pads. Old one had enough life left, but has became hard and started chipping off.
Brake Pad Kit - 2GS-W0045-0000 - ₹ 166.00
Pads are from FZ v2. Got 3 grooves instead of 1.
Disc pad pin kit. Got the entire kit for ₹ 45.00 from a local shop.
Thread Starter #351
Minda Electronic Indicator Flasher. Works well with LED indicators with proper flash rates, avoiding the need for ballast resistors. Minda ones were actually better than local ones with similar pricing. No relay ticking noise. Even the speedometer indicator works fine without skipping a blink. Paid ₹ 95.00.
Thread Starter #352
January 2019:
1.3L. Steady monthly usage of 1-1.2k.
Shell Advance Ultra 15W50. Was already tempted to try out and it goes for 2/3rd the price in Flipkart. MRP ₹ 1051.00, got for ₹ 649.00.
Bar code - Immature way of hiding the manufacturing date.
Nothing comes free, obviously a bit old, but not enough to be concerned.
Oil Filter - 21C-E3440-00 - ₹ 44.00
Priced bumped a bit, used to be ₹40. Made by MAHLE. There was Varroc make available at ₹28.
Oil change time.
Air Filter - 21C-E4450-00 - ₹ 204.00
Air filter prices wax and wanes depending on stock. Now the lowest.
Thread Starter #355
March 2019:
While washing, saw rear sprocket oil seal popping out. Despite multiple attempts, it wasn't fitting back properly. Removed wheel and checked and to my horror, the bearing was done. Don't remember replacing it. It was Sunday and no lathe was open to remove or buy new bearing. With tight schedules, taking off nor parking the bike was possible.
With many things running in mind, took a 1/2 inch socket and banged and the bearing popped out.
It was an NBC (Birla) make, model 6004 LH.
Rushed to the usual spare guy, who is open on Sundays. Voila and there was equivalent SKF bearing. Price was almost double the NBC make.
Model: SKF 6004-2RS1
Paid ₹ 230.00 (MRP₹ 239.00)
The bearing.
Cleaned and ready for install.
Place the bearing and gently tap it in. Use old bearing or a wooden block to spread the force. Don't hit on the inner ring as it can displace the balls/damage the bearing.
Used rubber mallet. Don't bang with your regular iron hammer.
Voila. Install complete.
Put back the old oil seal. It was deformed at places, though was intact and serves its purpose. Not happy with its torn look and itching to replace it as soon as possible.
Thread Starter #356
March 2019:
My Boy. (Ignore the waste bin [;)])
1'32'500
April 2019:
Long pending replacement. Current one turned yellow and got some scratches. Light output very much affected.
Headlight Assembly - 21C-H4300-10 - ₹ 990.00
Box was huge and didn't fit in bag. Had to put it on tank and do all the circus in traffic [frustration]
Neatly packed.
Front.
Rear.
Came with 35/35W HS1 bulb, which I already have a great collection removed from all the neighborhood bikes (upgraded). This one also goes to the useless pile.
... and rubber cap and park light bulb holder and bulb.
Side.
Lumax make, like the current one. Model 2187-02-00.
Thread Starter #357
Replacement:
Old yellowish light.
Undo 4 Allen bolts + 3 bolts, everything comes off. Disconnect lights also.
With upper cover.
2 nut springs and a rubber grommet with spacer in either side. Remove them as well.
Upper cover is fixed with 3 star screws.
All parts ready to be transferred to the new headlight assembly.
Upper Cover. Part Number 21C-F3121-00
Old vs. new.
All set.
Installed.
Beam adjustment. Highest position.
Lowest position.
Perfect
All set and one.
and a foam wash
How macho my boy is.
