Thread Starter #316
Hi deville..
Currently I'm using Yamalube FS 10w-40, in starting the engine feels smooth and responsive but after crossing 1700 km there is little vibration and harshness above 4k RPM.
I think you are also using same oil, what's your opinion about Yamalube FS ?
And which one is good for fz engine Motul 5100 or Yamalube?
I used 5100 for a long time before fully switching to Yamalube FS. I found the latter one better. Vibes after 4k rpm was common in most FZs, mine subsided with valve settings.
Thread Starter #317
April 2018:
Back to my favorite
NGK G-Power - CPR8EAGP-9 - ₹ 235.00
May 2018:
and my favorite oil
Yamalube Sporty Premium 10W40 - 90793AD41100 - ₹ 405.00
Changed oil filter as well since it was first change after engine rebuild.
Oil Filter - 21CE34400000 - ₹ 40.00
Lost in knee scrapping [evil]
Footrest Bolt - 901090820200 - ₹ 23.00
June 2018:
Monoshock was fully packed up. Change was inevitable. Bolt was stuck, so changed at Vinayaka Honda, a friendly neighborhood Honda garage. Total damage ₹ 3,071.00 parts + ₹ 450.00 labor.
Rear Shock Absorber Assembly 21C-F2210-00 ₹ 2,910.00
Yamaha OEM is Gabriel
U Nut - 95612-12100 - ₹ 55.00
Flange Bolt 90105-12057 ₹ 70.00
Collar 90387-12845 ₹ 36.00
Foam Wash
Yet another milestone: 123'123
Pune/Nasik
My FZ16 (2009) service is due now and will be serviced this weekend. Spark plug was changed 5k kms ago. Should I change the spark plug during this service. Engine oil will be Yamalube Sporty Premium.
Thanks in advance.
Pune/Nasik
Thanks in advance.
Thread Starter #320
Thanks in advance.
Recommended interval for stock plug is 10k km. Cleaning is required in between.
Auroville
Hi Dilip!
Thanks for creating such a detailed log of you FZ ownership and maintenance, love the photos btw.
Looking to bring my old workhorse back to life, thought I could get some suggestions from you. It's a 2009 January FZ 16. Used until July 2012 and been lying in a garage since then because I was outside the country. Just got back for a while, looking to bring it back to use.
What are the first things I should look out for in terms or maintenance/repairs/replacements.
Any other tips?
Thread Starter #323
Is there any advantage of installing a steel braided brake lines?
Is braking performance improve??
More crispier feel. Less effort.
Hi Dilip!
Any other tips?
Thanks.
Needs extensive work/cleanup since there will be lot of muck up inside engine. Tank, engine, carb needs thorough flush up. Throw away current tyres since its would be cracked up so much. Rubber parts and hoses needs replacement. All moving parts need lubing, especially bearings. Chain would be ruined for sure. All electrical connectors and switches needs cleaning. New battery. Would be a bit costlier deal.
Thread Starter #327
Brake shoes. The most frequently changed part nowadays, lasting barely 6-7k km.
Brake Shoe - 1GCF530K00 - ₹ 280.00
ASK brand.
Brake Shoe Spring - 905061500100 - ₹ 5.00
Brake Shoe Spring - 905061200100 - ₹ 5.00
Assembled for install.
Thread Starter #328
Back to square one. Motul 5100 10W50. My favorite. [evil]
After 46 liters of oil, heart stays with this one, 14th liter of 5100.
Yamalube Sporty Premium full synthetic was great oil, but somehow Barricade does not like it. Shift was butter smooth, but level dropped tremendously. Each time, ended up in some engine trouble. First time use, timing chain, rocker arm, valves packed up. Second time, cam needed rework. Third time, trouble free, but needed top-ups. Fourth time, engine overhaul. Fifth time, done with it, 600 ml after 2k km.
It was very cheap and tempting (₹ 400.00/liter of full synthetic oil), and never learned each time [frustration].
Ran 1k on 5100 and level still at full marking.
Made in Vietnam and 10W50 was pretty rare in 5100. Was looking for 15W50.
2017 stock. MRP ₹ 625.00, got for ₹ 530.00
2018 stock is Made in Thailand and MRP is only ₹ 540.00, but not seen anywhere in Trivandrum.
New crush washer.
Thread Starter #329
SMD Indicators
New project. SMD LEDs to replace regular LED indicators.
Latest consignment, Super Amber SMDs.
New series 2835. Dimension-wise same as 3528 found in regular LED strip, but x times brighter (x is claimed to be up to 4.6 times by various manufacturers)
Minimum order was 1000 pieces, was approx 70 paise per piece including tax and shipping.
Made in India by Kwality Photonics aka LED Chip Indus. Received in 2-3 days following payment.
Rear indicators of FZ version 2 aka R15. Clear Type.
(Rubber part is flexible. Front ones are sturdy ones, riskier in parking lots. FZ v1 had ultapulta, rear was sturdy and front flexible).
Indicator Assembly RHS - 2GS-H3340-00 - ₹ 140.00
Indicator Assembly LHS - 2GS-H3330-00 - ₹ 140.00
Thread Starter #330
Breakin'em'up
Held with single screw. Easily opens up.
The lens.
Putting a screw driver in the small notch helps split the lens and reflector. Needs to be gentle, can easily break the glass.
Cut off the protruding notch.
Unwanted parts.
Bulb is no longer Phillips.
Masked and primer'd.
Plastic primer.
Painted matt black.
Final. Unmasked.
