Amplifiers for Skoda Rapid
Hello Team,
I am planning to add Amplifier in my car. The basic configuration of the current ICE is as follows -
HU - JVC KW R400 (2DIN)
Front Speakers - Rockford Fosgate Prime Series Component System - R1652S
  • RMS - 40W
  • MAX RMS 80W
  • NOMINAL IMPEDENCE - 4 OHMS
  • CROSS OVER FREQUENCY 12kHz
  • 6db/Octave Crossover - High Pass
Rear Speakers -Rockford Fosgage Prime Series R1653
  • RMS - 40W
  • MAX RMS 80W
For above configuration I am looking for an amplifier and in future will add the sub woofer. Following are the amplifiers that I shortlisted from amazon and will ask my friend to bring it over with him from US. Need suggestion on which one I should go for.
Rockford Fosgate P400-4 400 Watt 4-Channel Amplifier
Product Features
Four-channel amplifier delivers 50W x 4 @ 4-Ohms, 100W x 4 @ 2-Ohms, 200W x 2 @ 4-Ohms bridged RMS
Variable front and rear high- and low-pass crossovers (50-500Hz at 12dB/octave)
Punch Bass adjustable bass (0dB to +18dB @ 45Hz) and treble (0dB to +12dB @ 12kHz) level control
Perfect for 4-way front-stage/rear-fill or 3-way front-stage/subwoofer systems
MOSFET output stage and power supply
Infinity Reference 475a High Peformance 4-Channel Full-Range Amplifier (Silver/Black)
4-Channel full-range amplifier with on-board electronic crossover and variable bass boost
12dB variable bass boost circuit is provided to optimize the low frequency performance of your system
Variable 12dB per octave electronic crossover allows you to optimize system tuning based on speakers and location
Full-range preamp outputs facilitate use of multiple amplifiers without the need for adapters or signal splitters
One-year warranty
Rockford Fosgate Prime R300-4 300-Watt Multi-Channel Amplifier
Product Features
Four-channel amplifier delivers 75 watts at 2 ohms, 50 watts at 4 ohms, 150 watts at 4 ohms bridged mono
Selectable high-pass crossover at 80Hz or variable low pass crossover at 50Hz-250Hz, both with 12dB/octave slope
Punch Bass adjustable bass level control of 0dB/+6dB/+12dB centered at 45Hz
RCA inputs for signal level input and pass-through jacks for system building
The input gain control is preset to match the output of most source units
Rockford Fosgate Power T400-4 400-Watt Multi-Channel Amplifier
Four-channel amplifier delivers 60W x 4 @ 4-Ohms, 100W x 4 @ 2-Ohms, 200W x 2 @ 4-Ohms bridged (RMS)
Class A/B amplifier with MOSFET output stage and power supply
Variable front/rear high-pass/low-pass filters with range of 50-500 Hz (24 dB/octave slope)
Variable front/rear bass (0dB to +18dB @ 45Hz) and treble (0dB to +12dB @ 12kHz) boost controls
Audiophile grade speaker connectio
Rockford Fosgate R400-4D 400 Watt Full-Range Class-D 4-Channel Amplifier
Tri-stage protection covers thermal, over-current and short circuits
On-board PEQ (Punch Equalization) with 18 dB of boost @ 45Hz
2/4 channel switch
12dB/octave crossover
Top mounted controls
Brand New Alpine MRX-F35 X Series "Class D" 4-Channel 340 Watt RMS Digital Amplifier With Bass Boost
Product Features
Alpine MRX-F35 X Series Digital 4-channel car amplifier
RMS Power Output: 60 Watts x 4 Channels @ 4 ohms
RMS Power Output: 85 Watts x 4 Channels @ 2 ohms
Bridged RMS Power Output: 170 Watts x 2 Channels (4-ohm stable in bridged mode)
Variable High- and Low-Pass Filters (50-400 Hz, 12 dB/octave)
Rockford Fosgate Punch P500-4 500-Watt Multi Channel Amplifier
Product Features
Four-channel amplifier delivers 60W x 4 @ 4-Ohms, 125W x 4 @ 2-Ohms, 250W x 2 @ 4-Ohms bridged RMS
Variable front and rear high- and low-pass crossovers (50-500Hz at 24dB/octave)
Rockford Fosgate P500X4D 500 Watt Class D 4 Channel Amplifier
Product Features
Tri-stage protection covers thermal, over-current and short circuits.
On-board PEQ (Punch Equalization) with 18 dB of boost at 45Hz
Variable crossover 12dB/octave slopes
75x4 @ 4 ohms
250x2 @ 2 ohms
Brand New Rockford Fosgate R400-4D Prime Series 400 Watt RMS Class D Full Range 4 Channel Car Amplifier
Product Features
2/4 channel switch
4 Gauge power/ground terminals
Cast aluminum heatsink
Pls pour in your views as I need to take decision very fast as my friend will be back in next week.
Bangalore/Hosur
Hello Team,
  • RMS - 40W
  • MAX RMS 80W
  • RMS - 40W
  • MAX RMS 80W
Product Features
One-year warranty
Product Features
2/4 channel switch
Product Features
Product Features
Product Features
75x4 @ 4 ohms
250x2 @ 2 ohms
Product Features
2/4 channel switch
Not much in to ICE set up but i currently have Boston Acoustics GTA-1005 in our innova and its really good and gives crisp hearing, but our swift carried Image Dynamics i5800, which i later changed/downgraded to JBL 2 channel for descent perfomance after seeing my friends's car but was never a let down
Its more of to check with ICE set up folks, and also very much specific to what genre of music is in your playlist
Thanks swift&furious for your inputs.
I thought of Boston but it's a little over budget for me. The only reason I am adding Amplifier is that I want to have crisp and clear music not just to add "Boom Boom" to show off. About your JBL 2 channel amplifier, how much it costed you and what is the model that you chose for your Swift?
Bangalore/Hosur
Its JBL 2 channel amp not much sure on the model would have to go down the seat to check it however i remember it costed me over 4K from JBL showroom which i picked it myself to ensure its genuine
Boston was able to source if from dubai during my brother's last visit to india, however its rich and really worth the buck, you can also opt for Audio dynamics my friend went for it and its compartively crisp to hear, more or less i think its more to do with the tuning[:D]
I will keep JBL as back up just in case if my friend is not able to bring the amp from US then I can go for JBL as cost looks OK (around 4K for good amp is very reasonable)
Hello Guys,
Got Rockford Fosgate R400-4D 400 Watt Full-Range Class-D 4-Channel Amplifier from US. Also got the wiring kit of KnuKonceptz - 4 Guage with the Amplifier.
Now, I need to add SubWoofer to my setup. Need suggestion on which sub woofer I should go with?
Also need suggestion on setup options
1. Connect Front Components and Sub woofer with 4 Channel Amp. Keep rear speakers connected to HU
2. Add a bridge to 4 channels and connect Sub woofer, front Components and Rear speakers to Amp.
3. Connect ONLY Front Components and Rear Speakers now and then add sub woofer after some time (cost cutting option)
Please suggest.
Hello Guys,
Please suggest.
First of all congrats for new amplifier. In case of subwoofers you have many options like pioneer,sony,jbl,hertz,polk,polkmomo,cerwin vega,kicker etc etc depending on your budget.
As for the setup options, i would consider the first option since it is necessary to power the components and the woofer well for good sound and avoid distortions. You can always add a 2 channel amplifier later to power the rear speakers if needed.
Hello Guys,
Please suggest.
Thanks Varun.
For Sub woofer, I have limited budget of around 7-8 k. One of the option is to add bass tube of 1000- 1100 w. Will the amplifier I got support these subs? Also request you and gurus in forum to suggest the sub options for this setup.
Thanks Varun.
In that budget you will get a good woofer. You will get most of the brands i have mentioned. 1000-1100w you are mentioning is only the max power. You have to check the RMS power (actual output). Since you are connecting the components and the woofer, please see to it that the RMS of both is well within the RMS of the amplifier.
I am personally using a 12" polkmomo woofer in a sealed box connected to a jbl mono channel amplifier in my swift and trust me i am more than happy. I had to get the damping done since rattling noises started because of the woofer and the components. But now its Nirvana! [:)]
Thanks Varun.
Checked the Rockford RF12 tube. The RMS of these woofers is 250W. My amp is 400W. I hope this setup should be OK.
n/a
Skoda Rapid - running power to amp
Hello there,
I am in the process of upgrading the sound system in my Skoda Rapid (2013) and am wondering if there is an easy way of getting power from the battery to the boot. Do any of you know if there are any pre-made holes in the wall to the engine compartment, or do you have to drill one?
Thank you for your help
