Adjusting Horizontal Focus of Maruti 800 Headlights
Varun560061
Re: Maruti 800 Headlight focus
Does anybody know the method of adjusting the horizontal focus of the headlamps?
Thanks
If you have type 1 or 2 head lights-There are 3 screws provided , one above the head lamp for height adjustment the other two below the head lamp for adjustment towards the right or left..[confused]
delhi
2 options 1. adjust focus using headlamp leveling switch on d dashboard for vertical adjustment. 2. if u have to set focus on left, loosen d right side screw little bit n fix a folded paper or add some extra washers in that extra space between d screw n d screw hole.this wud fix d lamp towards d left direction n same for right direction.I hope it solves d issue.
