Adding Gauges To My Maruti 800
Hello friends,
I am thinking of installing few more gauges in my Maruti 800. For eg: voltmeter, ammeter, rpm meter, etc. Can we install an oil pressure gauge or any more gauges. I want to fully modify my dashboard. What are all other gauges or modifications that can be done to a maruti 800 dashboard.
Even I am thinking of adding a voltmeter to my 800's dashboard/ A pillar.
Will follow this thread closely, thanks for starting this thread.
Varun can contribute a lot to this thread :)
Not much, you can get the amp/volt meter cost you around 1 - 1.5k.
You can also add pressure gauge but I think its not so useful..
Add an RPM gauge. That will be sufficient ...
@ loboprashanth I am thinking to fit the meters in a custom made center console. Will try to make one and place it somewhere in a center.
But i think i will have to cancel the plan of "GAUGIFYING" my car. as it may look weird. Will fit only a tachometer on the Pillar
Kolkata
After fitting all the meters in the dash and on the A-piller of M800 it will look like a fighter plane's cockpit. [;)] ( Just joking)
Take care while fitting the tacho on the A-Pillar. What tacho are you planning to fit?
