I forgot exactly which side the return wire is facing !. Will check again tonight for the shadows and will open and reinstall the left side unit if required !
HID is not succesfull in H4 unless you get a proper Bi-xenon retorfit. You can go for ones above or if budget allows, get morimoto kit. Get it professionally installed and stop the upgrade itch once and for all. Because this will be a serious upgrade after all. Installer skill is paramount.
Just be careful you choose an RHD kit for indian roads. Most kits including ones above are LHD.
Before it was like this. There was no throw on the road. Now where do I find a professional.
I talked with morimoto guy and showed him this picture he said it's fine. :/ I asked him as a favor. He then told me morimoto's are in stock.
I got the excelite brand HID'S. 35 Watt 4200k color.
He has not done a good job of mounting the ballast also. Left bulb was flickering sometimes.
Just wanted to know that pasting the ballast with the double sided tape provided in the box is sufficient to mount the ballast or not ?
Elantra doesn't have any space to properly mount the ballast.
