Here is my Yamaha RX135 thread
http://www.theautomotiveindia.com/f...young-devil-wheels-preloved-yamaha-rx135.html
Though RX 2T tank comes with a transparent window to check low oil level, I always wanted a indicator to show low oil level. Not because of laziness, I may miss to check oil level on busy schedules.
Went in search of TVS Max 100R oil level switch. To my surprise this particular part is out of stock in most of the shops and with TVS dealer too. Finally after 2 days of hunt got what I wanted.
Parts / Tools used:
Oil Level switch from TVS Max 100R
12V bulb (small one)
Candle (to heat the tank)
Knife (to cut the tank, I don't have drilling machine)
m-seal
DIY
a) Fixing the switch in tank
- Drained oil from 2T tank
- Removed the tank and plugged to 2T oil hose to pump
- Cleaned and rinsed with thinner
- Washed with detergent and dried
- Found a suitable are for oil level switch fitment and heated using candle
- Once when the plastic became soft, using knife cut to to few mm smaller than switch dia
- Use a file to finish the hole
- Cleaned the tank again and dried
- Fitted the oil level switch and packed with m-seal
b) Fixing the indicator lamp
I don't want to spoil the stock look by adding any additional lamps. Wanted to instal additional indicator but that should not be visible outside.
- Removed the pilot lamp assembly
- Opened it and found lot of space inside to accommodate one more bulb
- Initially fixed a RED LED in the NEUTRAL lamp compartment
- Though the light intensity is sufficient during night time, I am not satisfied with that
- Removed LED and fitted a small 12V bulb inside Neutral lamp compartment
- Additional bulb will share the -ve from neutral bulb
- Fitted back the assembly
c) Wiring
- Switch gets the input from Indicator flasher
- Output from the switch is connected to the additional bulb in neutral lamp compartment
Working
When the oil level is low (just touches the top of transparent window in tank) additional bulb in neutral lamp compartment starts flashing
I have taken Video of this, but I could not post it now (office laptop doesn't allow to upload the video in Youtube) and the size is close to 20MB
Here are the few snaps (Sorry guys, missed out few snaps, tank with switch assembly, bulb fitment, etc)
Parts / Tools used:
m-seal
DIY
c) Wiring
Working
