2001 Daewoo Matiz Right Side Tyre Issues
chennai
Hi I am having a 2001 Daewoo matiz which clocked around 65K.
Till now it bought smile to my driving.
But last two days a problem started, driver side tyre started rubbing to the mud gaurd nuts when I took right turn or go over a hump.
My workshop guy was not here, I called him and checked, he told for time being remove the mud guard and he will come by monday.
I did so, but today it started hitting the back side of the body where mud gaurd was kept. I am so sad about the things happening to my car. So gurusu any idea what can be the issue ?
I am not driving the car till my mechanic comes, but throw me some light on this. please
Varun560061
Check the strut and shocks it might have misplaced/damaged, Did you run over a pot hole at high speed which would cause this.
Also Just try to move a bit and brake see if the wheel move front and back if yes that's the strut causing this.
You are doing the right thing by not driving it till it get fixed.
See if the rims are bended and check your shocks,struts and the tie rod joint. in 1rst gear floor the accelerator and if you see the car vibrating because of this, then you have bended shocks.thank you
