Hello,
As i planned few months back, now i upgraded my wheels/tyres.
Reason for change :
-> Minor accident , in which alloy wheels took majority of the blow.
-> Alloys looking very old/scratched
-> Better Braking which i always want. (65 profiles slips while braking hard)
before: 195 65 r15
now : 225 50 zr16
Wheel specs:
Brand : Gmax Alloys.
Width : 7J
Dia : 16 inch
Offset : 35
Tyre specs:
Brand : Michelin
Model : Pilot Sport 3 (PS3)
Size : 225 50 ZR16
Everything seemed fine when the speed was below 100 kmh. Excellent Handling and more than Excellent Braking was very evident. I was expecting a stiffer ride. But it was similar to the 65 profile tyres in terms of comfort.
THE PROBLEM
As i took the car to the highways, again it took corners very sweetly, but when i took the car past 120 kmph , Steering started to shiver, and the whole car started to wobble . 2 days before changing the wheel/tyre i was doing about 140-160's comfortably with the 195 65's. So suspension is not the culprit.
Most of the sites say, WHEEL BALANCING should be the issue. But there are one or two cases where the wheel/tyre weight is also a problem. That was the reason i didn't go for 17 inchers. But does that still happen in 16 inch wheel? Or 225 is too much for Octy?? but i had seen 225 45 r 17 with no issues..![Confused [confused] [confused]](http://www.theautomotiveindia.com/forums/images/smilies/Confused.gif)
Experts, please shed some more light on this.
Will post the photos soon.
Reason for change :
before: 195 65 r15
now : 225 50 zr16
Wheel specs:
Width : 7J
Dia : 16 inch
Offset : 35
Tyre specs:
Brand : Michelin
Size : 225 50 ZR16
THE PROBLEM
