Maruti 800: Technical Issues & Solutions. This is a discussion on Maruti 800: Technical Issues & Solutions within The Technical Zone. Part of The Automotive Answers category; Hello varun, I need some help regarding my maruti 800.
Temperature in Delhi these days is around 45 degrees. I ... |
5th June 2014, 01:15 PM
#736 | V4
| Re: My Modified Maruti 800. Hello varun, I need some help regarding my maruti 800.
Temperature in Delhi these days is around 45 degrees. I got my car serviced last week from M.A.S.S. The A/c of the car is not effective as we all know about it. Well no worries about that but the engine temperature keeps on going above 50% maybe at 55-60% and Ac of the car stops cooling, horn stops blowing and the car is too hard to pull..its like that the car doesnt want to go any further.
It runs okay if there are 2-3 people in car including driver. But if there are 5 ppl then the problem occurs
Is this normal or is something wrong with the car?
5th June 2014, 05:23 PM
#737 | V10
Award Points: 10
| Re: My Modified Maruti 800. This is of course not Normal. Please don't use the vehicle too much and visit the ASS ASAP.
Are you using CNG in this car?Is it problem faced only after service or it was there? check the coolant. BTW, which model? and how many Km run till now? |
6th June 2014, 07:27 AM
#738 | V4
| Re: My Modified Maruti 800. Its on petrol.
Maruti 800 2005 model, covered 26500 kms till now. Few days back I had the problem with the coolant. It leaked and there was none left, faced many difficulties but somehow managed to take the car to the maruti guys.
They have changed the coolant, fix the leak, changed the belt, engine oil, basically the service was done. Now after service there is problem of heating...ac trips down horn stops for few minutes, but after that they start working. Amplifier is too hot that I cannot even touch it and the output is horrible in speakers.
Also, the average of the car has gone down. Previously it was 18-19 km/ltr. But now its only 12-13
6th June 2014, 05:13 PM
#739 | V10
Award Points: 10
| Re: My Modified Maruti 800. Which belt you changed?Is it required level coolant available in the tank? Start the engine and check the radiator fan working when engine get hot. |
6th June 2014, 08:00 PM
#740 | V4
| Re: My Modified Maruti 800. Quote:
Originally Posted by Releesh Which belt you changed?Is it required level coolant available in the tank? Start the engine and check the radiator fan working when engine get hot. | Today I went to maruti's service center they checked the whole car for almost half an hour and said that the car is completely ok. Then again after 50 km with 5 people sitting and ac on, the same problem occured. So what I did was stopped the ac. Then there was no problem. I think the engine is not taking much load. |
7th June 2014, 05:42 PM
#741 | V6
| Re: Maruti 800: Technical Issues and Solutions Hello ! Something is wrong with my AC vents, something is stuck there and it makes noise sometimes. I saw a piece of a glass inside, and sometimes dirt comes out when I switch on the ac. Can I open and clean these ac vents myself ? will these pieces of glass harm the blower or ac ? |
9th June 2014, 04:22 PM
#742 | V2
| Re: My Modified Maruti 800. Finally made it to m800 thread which is not dead ,like other sites.I to own an 2003 model completed 47k (ruby red) with interiors customize (gray---red & black).
I am planning to upgrade,my headlamps and grill of type-2,to type-3 headlamps and type-4 grill with Suzuki logo.
Problem=Not a direct fit,as the spare parts seller told me.
Solution=Need to cut the headlamp bracket, to fit it.BUT is it SAFE to do that.
Bought headlamps for 1.8k pair(lumax) ,grill & logo for 400rs.
__________________
MINE IS BETTER THAN OURS.......FUEL ECONOMY I MEAN!!!!
9th June 2014, 05:13 PM
#743 | Core Team
Originally Posted by solopro Problem=Not a direct fit,as the spare parts seller told me.
Bought headlamps for 1.8k pair(lumax) ,grill & logo for 400rs. | I had got this job done through a roadside but experienced mechanic. He slightly hammered the frame from inside to accommodate new headlamps.
350Z |
11th June 2014, 11:55 PM
#744 | V4
| Re: Maruti 800: Technical Issues and Solutions guys a little off topic but can i convert my non power steering setup in my zen to a power steering one.. |
17th June 2014, 05:13 PM
#745 | V6
| Re: Maruti 800: Technical Issues and Solutions antu you have a blown head gasket as car was overheated with no coolant. |
17th June 2014, 05:15 PM
#746 | V6
| Re: Maruti 800: Technical Issues and Solutions Quote:
Originally Posted by vroom09210 guys a little off topic but can i convert my non power steering setup in my zen to a power steering one..  | yes you can fit power steering but your car should be above 2000 mode( ie with MPFI engine) appx cost should be appx 10k Rs in case of any clarification you can pm me |
17th June 2014, 05:18 PM
#747 | V6
| Re: Maruti 800: Technical Issues and Solutions antu a small tip get your radiator cleaned by some good radiator mechanic, if you are a diy person then I can send you tips, you can try it yourself |
18th June 2014, 08:26 AM
#748 | V4
Originally Posted by nanhi99 antu a small tip get your radiator cleaned by some good radiator mechanic, if you are a diy person then I can send you tips, you can try it yourself | okay I will go for the radiator cleaning |
25th June 2014, 12:51 PM
#749 | V4
| Re: Maruti 800: Technical Issues and Solutions @varun i need some guidance on the R12 system fitted on my car , it is not cooling (minimal cooling is there ) checked the window on the drier bottle , it seems empty very little refrigerant is running ie it seems nearly clear.
i intend to replace the r12 with dupont mo49+. This is a drop in replacement for R12 and i bought 1 can of it also i got a ac manifold with three tubes and two pressure gauges which fits.
my query is whether i need to vacum the old gas and check the leakage (there seems to be no leakage as pressure is still there in Low side as well as high side. or i simply fill the new gas by following the filling process. |
25th June 2014, 06:19 PM
#750 | Honoured Member
Award Points: 20
| Re: Maruti 800: Technical Issues and Solutions Yes, its better you check for leaks before you fill in the gas. Where did you get the Dupont Mo49 ? |
| | Thread Tools | Search Thread | | | All times are GMT +5.5. The time now is 12:26 PM. |
