Quote:
Originally Posted by jarpickle Why don't you get MRF radial tyres?
Bridgestone tires are expensive.
Find out the prices from a couple of tire dealers.
What did he say was causing the noise?
Exide is better than amaron.
Not sure about the cost of the AC gas.
If you get two new tires put the old ones(of the same make and type) in the rear. |
completed repairs. and about the noise the mechanic said it is from water pump which is not a genuine part.
changed the battery
changed engine oil ,brake fluid, gear oil and coolent
installed new dynamo belt,
radiator hose pype clamp
and said he also installed air filter and some brake work charged 3200 including labour.
after taking my car back to home. i took a test drive to a 4 km drive, after stopping the car i noticed a boiling sound is coming from bonnet.
when i opened the bonnet the water is boiling and pouring out from radiator reservoir.
i called the mechanic he said wait for 15 min and after opeing radiator cap pour some water and ask to start the engine then and observe for start radiator fan.
i pour nearly 750 ml of water upto the top and start the engine after some time radiator fan is on. i told same to the mechanic.
he said go for a drive now, this time the water did not boil.
what is the reason for that is there any serious problem with my car.
happy news is i am driving the car very comfortably without any driving classes. Today i drove 8km in a moderate trafic root. I have to practice the revercing the car slowly when reversing i am going a bit fast
