Hi, all,
My 2006 Elantra CRDI is having some issues and any suggestions will be much appreciated.
For the past two years, when I take the car to highway and hit above 120 for a while, the engine check light pops up, RPM restricted to 2700, no matter what I do, it won't go above that, performance is also sluggish then. So I stop the vehicle for 5-10 mins, start the car, everything back to normal. Engine light goes off after some time.
So now, if I go for long drives, I keep the speed under 120, which is a good speed for Indian condition, but if I want to go above that speed, check light comes on and RPM restricted, if I keep it under 120, it will run all day long without any issues.
So I take the car to Hyundai, they said, EGR issue, so they cleaned it, same issue occurred, cleaned again, issue still persist. So now they want me to change the EGR valve, which of course they don't have stock available, it will take 15 days and 7500rs + Labor. I ordered the part.
Then my trusted mechanic in Bangalore told me you can block the ERG for the time being. He also said, some cars it's perfectly okay and for some it can cause issues. I chose not to do all that since I ordered the part.
Also vehicle has done 3.6 lakh kilometers without any major issues (TOUCH WOOD). I think there is only so much a vehicle can do.
Question is, is it okay to block the ERG? Will the new ERG fix the problem I am facing?
