I drive a Hyundai Verna 2012 model deisel
Recently the chamber of my car cracking open after hitting a protruding concrete slab for a mainhole. As the engine oil leaked I drove the vehicle to the nearby garrage about 400 odd meters. From there I towed the vehicle to hyundai service station. And the vehicle was in running condition.
The service manager has said that it will require complete overhaul of the engine and they are not aware of the damage has been done to engine... And the veggs in piston have developed a yellow mark due to over heat... Hover ever tbe piston is good
Suggest Pls if comlete overhaul is required.. Cause the agency is unwilling to just change the veggs set without having a complete overhaul
Thank you
Thank you
