Last year I had changed 2 heater plugs since I was getting glow plug indication on the dashboard, for 6 months they worked fine & in May 2017 it gave me the indicator again I took the car to workshop, they found that 1 of the new plug which they had changed has gone bad & its stuck badly & not opening at all, so they told me that out of 4 as long as 3 are good you can drive without much issues accept that glow plug indication will show on the dashboard.
So now I have to keep a check & every time I visit workshop I get the glow plug checked, yesterday visit one more older plug was found to be bad so I got it replaced but they had to literately struggle to open it & take that out. They say the 4th old plug is badly struck if applied force breaks it the half engine will have to be opened & taken to lathe machine to get that out with a major expanse of 10000/- and above.
What should I do to get the glow plug out?
Need solutions to this problem.
Ranjan
Ranjan
