Hyundai Verna Fluidic Dashboard Crackling Noise
CHENNAI
My petrol 2013 model Verna Fluidic. Gives noise like bursting of 4-5 crackers one after another in quick succession. Comes from dash board when I start the car or even during driving but not regularly. Any suggestions why it could be happening ?
Earth!!!
Re: Verna Fluidic Dashboard crackling noise
There are many reasons for this kind of noise from dashboard. General issue associated are -
1. Issue with starter motor.
2. Issue with alternator
3.Corroded battery terminal.
4. Low juice in battery
5. Issue with relays/solenoid/actuator/wiring
6. Motor vibration due to low torqued/loose bolt.
I suggest you to check your battery and clean it's terminals once. If problem still persists, please do try to post a video next time.
