My car is silent bellow 40Km/Hr but above that there is low frequency noise in the cabin.
To isolate this problem...
1. Wheel bearing suspect: I jacked up all four wheels one by one and checked smooth rotation of the wheel. All wheels rotates smoothly.
2. When in motion and speed above 40Km/Hr. I pressed clutch to isolate engine from gear. Noise do not reduce. Also in speed on empty road I switched off ignition and pressed clutch. Noise is still there.
Is this noise is due to JK tyre(more than five years old)?, Wheel bearing?, problem in differential?, or Dry CV joints?
Please help
Please help
