Hai Friends
I am using my brother FORD IKON PETROL 2007 MODEL. but till now i did not get any problem But recently it is giving problems
1. if we attempt to start the car it will start in 1st or 2nd cranking only and some times it refuses to start (no matter whether in cold or hot engine) if we check the car battery voltage its showing 12.8 volts (Almost battery is 4 yrs old it may be the culprit)
2.pickup issue : some time it refuses to climb 30degrees uphill and some times it will go smoothly on 60 degrees uphill
(i didnt observed any smoke from exhaustat)
