Hi Folks,
I have Ford Ikon 2002 make, which has Endure Engine. Few months back I had coolant leakage, which eventually lead to engine overheating. Vehicle breakdown on a holiday forced me to get it serviced at near by local garage. Head gasket, thermostat and valves were replaced. Since then the Engine rhythm completely changed, pickup seems to be less and with A/C on the car gets shutoff suddenly. The mechanic who did the work mentioned that the Engine tuning need to be done after it runs for few days.
After running it for few days coolant hose started leaking due to cracks, which I replaced it myself. Following things need to be addressed:
1. Engine tuning / valve adjustment
2. Coolant circulation and blockages if any
3. Shutdown when A/C is ON
4. Loss of pickup
I am from Hyderabad. Would be grateful if you can suggest a good Ford mechanic nearby L.B Nagar.
Thanks!
4. Loss of pickup
Thanks!
