OT: In this whole VW scam, I tried to analyse since yesterday, that this device in question was being used by the brand for so long, why did it come out so late? Why didn't anyone speak up earlier. Is it something that leaked all of a sudden? I do sense something fishy in its roots.
What I understood was, the software adjusted when it deducts that emission testing is done and significantly changed the operations of its powertrain to reduce emissions during the tests.
That detection was likely based on a combination of sensor data from the car, which might include steering angle (since cars on dynamometer tests don't make turns), front-wheel versus rear-wheel rotation speed, and a variety of other factors.
And please find the below article on how it was discovered
"This is one of the more interesting parts of the story: It wasn't discovered by the EPA at all, but by a clean-air group that tested VW diesel models to confirm its hypothesis that the latest diesel cars complied with all emissions standards while remaining much more efficient than comparable gasoline cars.
As recounted by Bloomberg, the International Council on Clean Transportation (ICCT) had studied European diesel cars and discovered that the on-road emissions of some models were notably higher than those measured in lab testing.
So the group decided to replicate its tests in the U.S., which then had much stricter emissions limits (known as Tier 2, Bin 5) than the Euro 5 standards in force in the European Union until this year.
They tested the cars on a dynamometer, or "rolling road," then measured their emissions in real-world use with a variety of speeds, road types, and demands on a road trip from San Diego to Seattle.
“We had no cause for suspicion,” John German, the ICCT's U.S. co-lead, told Bloomberg. “We thought the vehicles would be clean.”
The U.S. models too proved to have on-road emissions far higher than the maximum legal limits, so high that German termed the results "shocking."
On the open road, a Volkswagen Jetta TDI blew through the U.S. nitrogen oxide (NOx) emissions limit by 15 to 35 times. A VW Passat TDI (with urea aftertreatment) was 5 to 20 times the maximum.
A BMW X5 xDrive 35d diesel crossover equipped with urea aftertreatment and tested at the same time, however, met the emission limits under all circumstances.
The U.S. EPA and CARB opened a joint investigation into the cars in May 2014, but it was not publicized.
Last December, VW recalled nearly half a million cars for a software patch to fix the problem--but CARB found it didn't enable the cars to meet the regulations. Matters came to a head on July 8, when CARB informed the EPA and VW of its findings.
This month, the EPA refused to certify VW's 2016 TDI models for sale, based on its real-world testing of the vehicle's emissions--which exceeded the legal limits, even though its lab tests didn't.
That's when Volkswagen admitted that it had installed the "defeat" software. The EPA went public within a few weeks."
And please find the link below(letter sent by EPA to VW)
http://www3.epa.gov/otaq/cert/documents/vw-nov-caa-09-18-15.pdf
