My 2012 Swift VDi has started displaying the EPS light even after starting. The light first came up after I started the car after a week of inactivity. However, the EPS light comes up intermittently, sometimes at cold starts in the morning or after a long drive and shut down and restart.
I had shown it to MASS earlier and the error code registered was C1113. The SA cleared the code up after tightening couple of fuse sockets and since the last few weeks it was fine until last week it shows up again.
Had to start and shutdown the car a couple of times before it finally went away.
The car had an under warranty replacement of water pump a couple of months back. The pump bearings failed and were producing noise, hence it was replaced along with coolant. Not sure if its related. My guess was maybe rats chewed up the sensor wires, or there might be some loose connections.
Kindly help!
Request to Mods: I had posted the same in the Swift : Technical Issue & Sultions thread, but did not get any response hence, posting the same as a new thread.
Kindly help!
