Hello,
My stock GoodYear tires has run 30,000kms. There is problem with one or two of the tires which is put at rear. At low speed the car wobbles. I ran one of the tyre with a small puncture for few hundred kms (as air was leaking very gradually I didnt noticed it).
I suspect the problem could be in only one tyre with the side walls. I was advised to replace the tires while doing wheel balancing/alignment (I do balancing/alignment for every 5k-kms). The threads are fine. Should I replace all the 4 tires? Will it cause any damage to car chassis or to breaks if I continue running it?
Please advise. Thanks!
