Hi TAians
My nightmare has again started after the service at ARAS motors. again!
Suddenly, my cars pick up has gone down considerably and engine noise is high when i try to press the accelerator to increase the speed. Even when the accelerator is pressed down to the floor completely the RPM increases but there is no pickup as the speedometer slowly raises so badly that I couldnt overtake an vehicle in front of me.
What happened to my car? can somebody explain?
In highway driving when the accelerator is pressed completely to the floor the RPM does raise upto 3000 rpm but the speed stays only at 110-120km max.
I checked the engine oil and it was dark black and the oil was at its maximum limit. why this happens especially after each free service (at my dealer ARAS motors) ?
Also the car steering doesnt turn back to (original state) 90 degrees after each complete left/right turn that I make. I dont know if it is the power steering issue or whether the steering rod is not aligned.
can somebody help me here?
All these issues started only after the recent service, and it was not before
so TAIans I need you Help..
A big Advance thank you
