Chung Noise From Driver Side Front when Crossing Humps
rajpura
hi i have some problem in my vista 2010 tdi clocked 63000on odo need help
from past 1 month i notice that some kind of noise like chang when crossing humps is there any major problem or i have to go for suspense overhaul [anger]
i also notice that comparison to other cars i m felling that car engine leval is going down at last service TASC told that have to change a part which will not allow the engine level to go down but they also said there is no emergency [anger]
Re: chung noise from driver side front when crocing humps
can you provide more inputs on the problem?
Is the noise from front or rear?
is the noise coming near the wheels or at the centre?
do you fell any steering wobble or the car pulls to the side when breaking?
rajpura
noise is coming from near the front driver side wheel
and there is no steering wobble only some vibration in interior when car is in neutral
allhyundaicars
I used to get this noise in my i10 whenever car went into a pothole. Tie rod and arm's bush were the culprit. Replaced them and there's no noise.
rajpura
last day i went to mechanic and he said that suspension rubbers r hard he said that when you go to wash your car to any shop tell them to spray diesel at the bottom of the car and also on suspension ????????
now my question is that can we change those rubbers ? or i have to go for complete suspension change ?
This can be temporary solution but better get the bushes changed if not done earlier since you bought the car.
Only bush change should be approx 1000-1500 with labour (both sides).
In case you have to change suspension (both sides ) would be 7000-9000.
