I need some suggestions on upgrading the alternator on my Esteem. At idle the multimeter reading is 12.78v but at RPM above 2500 the voltage increases to 14.35v. I haven't tried revving the engine too hard to check the increase in voltage further. After driving with headlights and AC ON at speeds of 45-60kmph in 4th or 5th gear, I have had issues starting the car after a quick stop as the battery did not charge. I was searching the internet and found low voltage to be a common issue in Esteems.
I am thinking of the following options:
1). Replace it with a new one of the same type. (Not sure if this helps)
2). Upgrade to another type maybe from swift diesel. (No reference found)
3). Change the pully with the one that has lesser diameter, so that I get higher voltage at low RPMs.(Would this increase wear and tear?)
Also, I am looking for reliable car repair shop in Wakad, Pune. I need to get some other issues sorted. Like clutch adjustment, hard 1st and 2nd gears, a noticable thud after releasing the clutch in any gear. Jerks while cruzing at lower RPM range of any gear, Shuddering sound from front suspension. Power windows not working.
Any good suggestions and pointer would be really helpful.
Thanks in advance.
Thanks in advance.
