Hello all. I have been observing this from few days in my Safari dicor 2.2. At speeds between 50 to 65kmph in 4 th gear when the steering wheel is in neutral position(neither turned left or right) then the wheel wobbles a lot. It doesn't wobble when I turn it to either side. The wobble vanishes as soon as I increase speeds above 65kmph. I can feel this wobble on good tarmac roads so bad road conditions are not the cause. It slowly started after the new tyre change. The wheels were balanced and aligned after tyre change by the same MRF dealer who did the tyre change. Of issue was about the shims which were added on the right wheel and one shim removed from the left!
I drove the vehicle for about 6000 km before tyre change and I never encountered this kind of wobbling.
Did anyone face this problem before? Can anyone throw some light on this? I am concerned about the wobbling as I would do a long trip in the second week of July.
