In cold condition(i.e. in the morning) the scooter starts in one kick(manual) and the idle speed is good - the rear wheel turns slowly(not very slowly); but once the engine warms up after about a 10 minutes ride, the idle speed drops so much that at idle throttle the engine stops and to keep the engine running, at traffic stops, have to hold the throttle higher than idle position, and it even becomes very difficult to kick-start; it can only be started by starter with the throttle held higher than idle position( all this time the choke is kept on). What could be the problem and how to solve it?
What I have already tried: Increased idle screw setting(on carb) when engine was warmed up after 10 mins of ride, but this resulted in a very high cold state idle speed.
