All,
Getting straight to the point. I have had my VW Polo Trendline since Aug 2012 and have not faced any issues except one. The AC cooling keeps getting cut off every now and then. Every time I think of taking it to the service station, that particular day the AC would work in full swing and in fact I have had to reduce the fan speed a bit. I finished my second service around a month back and I hoped they would find out the problem since I had already mentioned it on the "Work to be done" sheet. It turns out the AC was actually working fine and was working fine for two more days after the service. But after that the woes continue.
Whenever I switch on the AC I can hear a *click* sound which, i believe, is the AC cooling sound. But after a while the cooling stops and gets stuffy inside. Also, whenever the car goes over a pothole, the AC cooling starts again and remains like that, sometimes the whole time when the car is on, or till the time it is in mood!!
Could someone advise if they have faced a similar problem with their Polo and/or is there a solution for this issue.
PS: As of today, the AC cooling is working fine.
