hello,
My Alto lxi 2010 model is currently having some Rattling Noise problem. It began from dis January 2014. When the car is idle, the rattling noise from the gearbox can be heard. But as soon as i depressed the clutch fully, it goes away and also when accelerated, the noise goes away. In running, noise cant be heard except when AC is switch on. In idle state it makes the rattling noise and when ac is switch on, the noise is like mini generator sound.
Therefore i took to the mechanic, he 1st told me to change the gear oil, which i did, but it didn't resolved the problem, he then said that he have to open & check d gear box & also at the same time warned me not to have the gear box open currently, as he would do the work later when my clutch plate is worn out (currently, the clutch has become little hard but it is working in the way it sud be with gud pick up).
What sud i do, as he said noise wud not cause any trouble to the car except the large sound in idle state.
