As per my experiance, This machine is way better. I have seen this machine in MASS and used it in last december.
Though i will go to MASS for other issues, Ac check up and gas top up i done from local AC technician(even MASS guys sending cars to him for major AC works).2 year befor i replaced AC condenser in my car at his shop. But After this i always felt Ac cooling was less in my car on hot day times. In every 2-3 months, i visited him and told about my issue and he told me it is fine and has enough gas . no point in adding more gas. But i felt low cooling. later i visited to another techinician. he just refilled gas and told it is ok.Cooling was ok for some months and agian i felt it is low. When i visted MASS, they checked and told that gas is less.
I had to buy the small refill can from them and after they conected the car to machine. First they removed gas from Ac lines, then removed Air and they filled r134 gas as per the service manual with them. Pressure shown in the machine was 510(not sure about the unit). Earlier it was below 400. Cooling is perfect now. they connected the refill can(275ml) to machine and it sucked the gas from the can to the bigger cylinder
As per MASS technicians, Machine can fill with more pressure and it will be accurate than ordinary cylinder and valve tech. When you fill through machine no air will come into the line.
Except connecting the machine to L & H valves, nothing they have to do in car. machine will do the refilling and oil, once they entered the required value.
