Hey Guys some help required for our 2004 WagonR. Car has done just 44K kms.
There is a hummm type of noise coming inside the cabin whenever the engine is on. It vanishes when I depress the clutch. This noise also comes while the car is moving.
Humming increases if I rev the car in neutral while stationary. The noise is not loud.
I am assuming it's not a wheel bearing noise since it's also coming when the car is stationary.
The clutch was overhauled recently at MASS and the car has run just 400 kms post the clutch O/H. They changed the clutch plate, pressure plate, clutch release bearing, clutch cable and some seals both right and left side. They didn't change the flywheel though, said it's in perfect condition.
Guys any pointers what is this noise as I will only be able to take car to MASS on Saturday and I also don't want the SA to take me for a ride.
Is it due to a bad clutch job?
Thanks.
Thanks.
