Hello
I have a '95 Maruti 800 (carb). It had been lying idle for 8-10 months. Hadn't been started even once. The battery was dead so I fixed a new one today. Tried starting it but it just won't start. Battery's brand new so no problem there. Starter's working like a charm. I don't think the engine is turning over (cranking). The starter just keeps making that starting sound. I tried it 6 times for about 8 seconds each, 1 minute apart. Tried the choke too. Are the pistons jammed? Should I pull the spark plugs out and spray some engine oil into the cylinders? (If I can find the damn spark plugs, that is) How do you manually crank the engine? Where can I find the harmonic balancer? Or should I simply call a mechanic?
Thanks in advance.
Thanks in advance.
