Two years back i wanted to install lpg kit on my matiz but i wanted to have complete information first, i could not find such technical information i have a evaporator with me which was taken out from a omini, i am uploading inside view of this along with information hope will be usefull for readers
evaporator from both sides
main things are water inlet
water out let
gas input
gas output
idling control
solinoid valve
working is very simple it has two diaphragms one regulated the supply of gas from input depending on the input presure input valve opens or closes this is controlled by a spring as input pressure is high of order 30psi
see pics
water out let
gas input
gas output
idling control
solinoid valve
see pics
