hi everyone,
I am facing some problems with my 2010 model K10B wagonR and I thought that i could discuss it here on TAI so that you people could help me sort out the problems and bring back my Waggy to perfect state of health.
Vehicle: 2010 WagonR
Mileage till date :12526 km. All services are done periodically at MASS.
Few problems were lately developed while others came up quite early(within months from delivery).I will try to give you each problem in detail.
1.Engine coolant flows out from the reservoir(or overflow) can.
This problem is present now for almost an year.I have showed it to the service people (MASS).They at first changed that can's cap but the problem was not solved so they then replaced the whole gasket(or can) completely but still the problem persist. now the problem in detail: After long journeys or heavy driving i can see that the coolant had overflowed through the cap area of the reservoir gasket.It flows out in small amounts like spills.In small drive this doesn't happends.I really doubt whether my engine is over heating.What do you think guys?
2.Recently my AC compressor developed a strange habit of switching ON and OFF very frequently(within 10 -20 seconds interval).I know that after switching on AC, the compressor will automatically switches on and off by itself in every vehicle according to temperature or something but here in my case it does this very frequently, even before cooling the cabin efficiently as i have noticed that AC performance has come down. Will it be due to the engine over heating problem?The sound with which the compressor switches on(that clanging sound that we hear when we switch on our AC )is now very frequent and easily noticeable even to co-passengers. There is also heavy drop in engine performance during this switching on and off process, more when compared to early times? I observed that my rpm comes down by 1000 to 1200rpms during this process. Early times i remember that while switching on AC the rpm needle only comes down by some 200 to 400 rpms.(i checked this by cruising the vehicle at about 2500 rpms , when the compressor comes on the rpm comes down to 1500 rpm range and i have to accelerate harder to keep up the momentum now).I have a feeling that the engine performance has decreased recently. Breaking also has decreased. I assume it to be some problem with the engine overheating. What do you think guys? And also when this happens my headlights dims noticeably with every switching on off compressor making night driving difficult as this happens every 10 to 20 seconds.
3.Hissing sound(sound like air going out through small gap or more correctly vacuum leak) is heard from back of the steering wheel( or from behind the driverside dashboard area).This sound comes only after running for about 10 kms(experimented) or after the engine heats up. More pronounced when the AC is switched on.This sound suddenly comes up when i reach about 2300 or 2500 + rpm range and is clearly audible in all gears. I couldnt here it when the car is in neutral. The sound comes up at all gears when the rpm reaches about 2400 mark and continues even at higher rpms but at the moment I press down the clutch the sound vanishes and comes again when I have reached the 2400+rpm mark. As I said earlier this sound also appears only after the engine had heated up. On surfing through net I came to know about vacuum leak from some engine component can cause this which inturn can cause poor performance of power steering, power-brake and engine as a whole. Any idea on this point?
The other thing that I have observed is that the radiator fan also switches on and off frequently with AC compressor(simultaneously within 10-20 seconds)
Now to sum up my car now has reduced AC performance, Reduced breaking performance and even reduced engine performance.The throttle response is not correct either as I have to put in more acceleration than usual at various situations.
So guys please help.The problems 2 and 3 are not reported to mass till now as I didn’t get time to get my car to them. My 5th service is due this month and I hope you will give me some suggestions so that I can pin point the matters to them.
Thank you.
Thank you.
