My 2009 Linea MJD Emotion covered 54k km. From 40k km I could hear some abnormal noise from the Front LH Suspension when ever I drive over road patches or small potholes. Magnitude started increasing day-by-day.
During 45k service we suspected Link Rod being the culprit and changed both LH & RH link rods. Noise reduced a bit.
In 50k km noise started again. I suspected the elastic pads, bit could not open the suspension for past 2 months as I was mostly out of station or bundled with heavy work.
Last weekend taken the car to my regular mechanic and removed the LH strut assembly.
On removing we found that the strut to body mounting hole dia is bit larger than required.
Explored the whole garage and found some plastic washers (mechanic said it is used in some car gear lever mounting or gear shift cable)
Inserted the washer in hole and its perfect. Grease packed the elastic pads, fitted back the assembly and went for a short TD in bad roads, to my surprise noise disappeared.
Total cost: 1200 INR (Including wheel alignment, water wash, interior cleaning, all fluid top-up, front LH brake cleaning, labor)
