My Indigo TDi is in for an overhaul. The job will be done today and tomorrow.
The jobs will be done at two levels, engine and turbo.
Engine work :
1. Piston rings change.
2. Head Gasket replacement.
3. Oil circulation will be checked and leaks, faulty valves will be changed.
Turbo work :
Cost break up :
Mechanic quoted engine job at Rs 11000/-. On my inquiry of parts price,
Piston rings - 1500/- (Tata Original)
Head gasket - 1000/- (Tata Original)
Engine Oil and filter - 1100/- (Valvoline 15 w40, Purolator filter)
So, the rest should be labor.
Turbo work :
Turbo repair - 2800/-
New turbo - 6500/- to 9000/-
My queries :
1. Whether the above mentioned oil (grade) was not good for the turbo?
2. Is there a 20 w50 grade oil available with any brand?
3. Which turbo to buy in case a new one is required? The original was a Garret piece.
Engine work :
Apart from the above 3, what other things should be checked? Excess oil consumption, blueish black smoke, loss of power were the typical bad rings symptoms I was experiencing. Another weird experience was very very low fuel economy in city and good economy (17-18) on the highways.
I am getting the job done from a mechanic, who is reputed and trusted for the job and is a Tata-Mahindra diesel expert. According to him only rings change and head job is required, and the engine will easily do another 50-60 thousand kilometers.
Turbo work :
Turbo will be opened. 2 days back while cleaning the air filter, the connector pipe had some oil. Mechanic then said that the turbo is damaged. He suggested the following :
1. Take it out and get it repaired from Bosch, Aurangabad at a cost of Rs 2800/-. Bosch will repair it, only if it is repairable.
2. Change it straight away at a cost in the range of Rs 6500/- to 9000/-
3. Yesterday he said, if the oil in air filter and turbo connector may be due to blow-by, he will inspect, and if not required, no need to repair or change the turbo.
It will be good to state that the 2 minute idle before shutting off the engine and after turning on the engine rule was strictly followed all the 6 years, and the air filter was also cleaned / replaced as per manual recommended durations.
Cost break up :
Turbo work :
My queries :
