my maruti 800 is behaving wierdly these days and here are the problems
earlier when my battery drained , i did bump started the car and since there was no battrery light comming on i drived it for around 10 km . i've noticed that the horn was making low sound . i thought horn was bad and neglected . but while returning to my house too he horn and indicators were dim . so thought of getting it checked at car electrical shop.so went there and heres the conversation
ME: the horn and other electricals are dim , please check them ( i had to request as it was closing time)
MECH: put the key in ignition and said the battery light is not comming , hence alternator is not charging the batterty
ME: but i've done 10km run and my car didnt stall in between and there was no battery light when engine is on
MECH: (checked and confirmed the same) connected the voltmeter and said that the voltage was around 10volts and recommended to change alternator
he also checked battery with a device which has a floating indicator and said one of the battery's cell is broken (in his words weak)
so i got the alternator changed and but even now some times the battery gets drained. Got frustated and took it to mechanic ( another one) . what he did was , started the car by pushing it and then checked the reading with voltmeter these were readings at idle speed 13.44volts and after 10 min switching off engine , checked again 13 volts and again checked this time revving the engine 14 volts.
inspite of this today at cold start (after 2-3) attempts the battery drained,again bump start.
the other issue is when choke is fully closed (choke lever pulled to extreme) as shown in picture my car refuses to start even after attaining operating temperature i wonder why
and when i pulled the accelerator cable to check accelerator pump i noticed white fumes making their way out from carb and in second picture is that
secondary butterfly i might sound stupid but please help
