Tyre burst is one of the most deadly things that can happen to you when you are driving your car at very high speeds.You can lose control of the vehicle,ram into divider,or venture into opposite lane,and even worse your vehicle can completely flip upside down.Very recently much cherished automotive blogger Sam Kapassi died due to tyre burst(R.I.P. Sam/yeti).How to prevent tyre burst and how to handle it?
The goal in any rapid loss of tire pressure or "blowout" is to keep the vehicle balanced and controllable. Do not panic. Any over-reaction by the driver -- including slamming on the brakes or abruptly removing your foot from the accelerator -- can result in a loss of vehicle control.
In any blowout situation, it's most important to first remember the 2 things you should NOT do:
Do not step on the brake. As instinctive as it may be, it's the worst mistake you can make in any tire blowout situation. Applying the brakes will cause an even greater imbalance on the vehicle's stability.
Do not abruptly release your foot from the accelerator. This is the second worst mistake you can make. Rapidly releasing the accelerator causes the vehicle to transfer more of its weight from the rear tires to the front tires. With a flat tire, this can lead to loss of control of the vehicle.
Instead, in any blowout situation, you should follow these 3 steps:
Gradually release the accelerator .
Correct the steering as necessary to stabilize your vehicle and regain control. Look where you want the vehicle to go and steer in that direction.
Once your vehicle has stabilized, continue to slow down and pull off the road where and when you judge it's safe to do so.
Remember, no matter which tire blows out -- front or back -- the do's and don'ts for safely maintaining control of your vehicle are exactly the same. The only difference between a front and rear tire blowout is that you will feel the force of a front blowout more in the vehicle's steering, while you'll feel a rear blowout more in the seat or body of the vehicle.
Source:weather.com - Driving Safety Tips - What To Do When You Have a Blowout
@MODS: If any such topic exists please merge this thread.Thanks.
